Activity Forums Adobe Encore DVD Warning: Encore CS3 can kill Blu-ray BR-RE media!
  • Warning: Encore CS3 can kill Blu-ray BR-RE media!
    Posted by Frank Wylie on July 13, 2009 at 10:05 pm
    Just a word of warning; I have found that Encore will fail 99% of the time mid-point on erasing a re-writable Blu-ray disk, thereby rendering it a coaster! (YES, I am checking the “erase disk” box when this happens!)
    The disk is not mountable and cannot be recovered in any way I have found…
    If you need to re-use a BD-RE, use another utility like ImgBurn or Nero or Cyberlink Hi-Def Suite to erase or reformat the disk PRIOR to letting Encore anywhere near the disk!
    At $40 USD a pop, making coasters gets old REAL quick!
    word to the wise…
    Frank Wylie
    “The camera is a base instrument; you must do violence to it…” Orson Welles
    Larry Applegate replied 16 years, 9 months ago 2 Members · 1 Reply
  • Larry Applegate
    July 14, 2009 at 5:44 am
    Hi Frank,
    it’s odd that you can’t erase the disc and fix it with another of the utilities you mentioned. Have you tried to do that on a Mac with Toast?
    We have a Mac burning program also, and would like to try one of your failed discs.
    Regards,
    Larry
    https://blustreak.dvdafteredit.com/
