Activity › Forums › Blackmagic Design › Wanting to get it right!
  • Wanting to get it right!
    Posted by Grant Goss on December 25, 2008 at 7:05 am
    I’m new here, and maybe I’m in the wrong place to be asking this question, but here I go.
    I’m building the following system, as a starting point.
    Blackmagic design DeckLink HD Extreme card.
    3ware Raid controller card. 9650se 4lpml.
    4 WD 1TB 7200rpm Caviar Black HD. Raid 5.
    WD 3oogig 10k VelociRaptor HD for the OS.
    ASUS P5E Deluxe Motherboard.
    Intel Core 2 Q9550 Yorkfield Quad Core 2.83 Ghz
    8 Gigs of Corsair XMS3 DHX Ram.
    Cool Master Hyper 212 Copper/Aluminum heat pipe CPU Cooler.
    PC Power 750w Quad power supply.
    LG 22x SATA Dual Layer DVD+/-RW
    AS for the OS, Windows XP Pro.
    Adobe CS3.
    I’m just using this system at home with low to mid end Video.
    One more Question.
    Will the Sony XDCAM EX PMW-EX1 work well with this system?
    Thanks for your time and input.
    Sam Carleton replied 17 years, 8 months ago 3 Members · 6 Replies
  • Aristides Tiropolis
    December 25, 2008 at 6:05 pm
    [Grant Goss] “AS for the OS, Windows XP Pro.”
    Why would you buy 8 gigs of memory and install WinXP? Five of them will be left unused.
    As for the rest of the system, it’ll handle the ΕΧ-1 footage fine, but you could always go with the i7 architecture, more performance less power consumption, more PCIe slots on X58 mainboards, why not?
    You could also add a blu-ray writer for backup…
    December 25, 2008 at 6:10 pm
    Also, the P5E is a DDR2 motherboard and you’re stating a purchase of DDR3 memory
  • Grant Goss
    December 25, 2008 at 9:35 pm
    Could I run Vista Ultimate 32bit version without running into driver problems with the Blackmagic card and Adobe CS3? Then I could use all the ram.
  • Grant Goss
    December 25, 2008 at 9:41 pm
    Re: Wanting to get it right!
    by Aristides Tiropolis (Aristides) on Dec 25, 2008 at 12:10:32 pm
    True the P5E is DDR2
    P5E Deluxe is DDR3.
    December 26, 2008 at 4:42 pm
    The P5E Deluxe is DDR2 as well.
    Vista 32 will support a maximum 4Gb of memory. Only x64 systems support more than 4 gigabytes of memory on windows.
    Vista ultimate x64 supports blackmagic and The Adobe CS3 suite.
  • Sam Carleton
    January 3, 2009 at 4:12 am
    As Aristides said, you need a 64-bit OS. If you have a close look at the web site, you will see that they DO have drivers for both Vista 64-bit and XP 64-bit, take your pick.
    By day I am a software developer. My laptop is 64-bit Vista and I never have any driver issues. Well this is not 100% true, a 4-year-old blue tooth usb dongle did not have drivers for the laptop, but it was 4 years old.
    Personally, if I where you, and I am sort of because, I too, am building my first editing system, I would not install XP on a new machine, the OS is 6 years old! Vista w/ SP1 is a wonderful OS, far better then XP in many regards and simply far more modern.
    Go with 64-bit Vista and you will be a happy person!
    Sam
