Activity › Forums › Adobe Premiere Pro › WANTED: Turn off all filters
Posted by Morten on November 18, 2014 at 11:36 pmWhen working with multiple filters, and Speedgrade looks, performance can take a hit. If there only was that magical button that could disable all filters in a Sequence…
– No Parking Production –
Adobe CC2014, 3 x MacPro, 3 x MbP, Ethernet File Server w. Areca ThunderRaid 8
Sean Pollaro replied 11 years, 9 months ago 6 Members · 9 Replies -
Alex Udell
November 19, 2014 at 12:39 amyep….smoke has that…
Alex Udell
Editing, Motion Graphics, and Visual FX -
Alex Udell
November 19, 2014 at 1:57 pmPaul’s right that this would be about the closest you’re gonna get. That way you can just disable the track.
Probably not well suited to a project in progress, but certainly something to consider in the workflow of subsequent projects.
Alex Udell
Paul Neumann
November 19, 2014 at 2:33 pmYou know you can copy a clip to a layer above it then turn it into an adjustment layer. Then highlight the original clip and remove the effects. This would allow you to easily enable/disable all the effects for that clip or clips if you have multiple adjustment layers selected.
Alex Udell
November 19, 2014 at 2:55 pmAhhh I didn’t know you can change it to an adjustment layer….
or are you doing a media replace?
Alex Udell
Paul Neumann
November 19, 2014 at 3:23 pmNo. Just right click and select Adjustment Layer. It will retain the effects. It keeps the name so that part can seem deceiving. Pretty handy. Rather than dragging out a bunch of Adjustment Layers to fit each clip you can just do the copy and change thing really quick.
Other cool uses for this function too, though some have been rendered a little obsolete by the new mask tools that accompany every effect now.
Kevin Monahan
November 19, 2014 at 7:07 pmHi Morten,
Add your voice here: https://adobe.ly/feature_requestThanks,
KevinKevin Monahan
Support Product Manager—DVA
Adobe After Effects
Adobe Premiere Pro
Adobe
Follow Me on Twitter! -
David Patterson
November 20, 2014 at 3:49 pmPaul – Thanks for the tip about changing a video clip to an adjustment layer. Great trick!
Sean Pollaro
November 20, 2014 at 9:37 pmPlease, everyone go to Adobe and voice your opinion on this. I’ve been submitting this request since CS5.. We had it in FCP7 and it saved my butt on many occasions. This is especially needed now because of 4k. Thanks!
