Activity › Forums › Apple Motion › Want to use motion text animation, but LONG render times prohibit?
  • Want to use motion text animation, but LONG render times prohibit?
    Posted by Todd Reid on August 7, 2006 at 3:20 pm
    I’m created a text animation for a show I’m putting the finishing touches on.
    Its a “previously recorded” type of thing.
    I have a preset animation then it hold for the remainder of the show (28 minutes).
    The render is well over an hour and much too long for my deadlines. I started by importing the project
    into FCP, too long. Then I exported a quicktime, same long render.
    Any suggestions on how to get a simple motion project to render faster in Final Cut Pro?
    I’ve had to bag the idea, and use FCP text, until I can shorten this render fiasco.
    Chelsea Womack replied 17 years, 7 months ago 6 Members · 6 Replies
  • Peter Wiggins
    August 7, 2006 at 3:28 pm
    Can you not export a movie for the moving bit and then make a freeze in FCP?
    Peter
    Free Motion Templates
    https://www.peterwiggins.com
  • Todd Reid
    August 7, 2006 at 3:34 pm
    I tried that, but the freeze looked a lot different then the .mov, fuzzier (tried the whole -1, 0, 1 thing nothing helped).
    I also tried matching the .mov with FCP text.
    FCP treats this particular font differently, its much fatter in fcp than motion, even though its the same font, same parameters.
    So no matter how simple or complex the motion file is, am I in for long renders?
    For complex stuff I can handle it, you’d think two words would go quicker.
  • Greg Niles
    August 7, 2006 at 10:54 pm
    You can try exporting the frame you want to hold from Motion as a single frame in a format that supports alpha channel, like PSD or PNG or TIFF. Then import that into FCP and place it over your video track at the hold point, trimming the Motion animation to the frame before. Should be much faster to render.
    — Greg
  • Duncan Craig
    August 8, 2006 at 7:26 pm
    ”I tried that, but the freeze looked a lot different then the .mov, fuzzier (tried the whole -1, 0, 1 thing nothing helped).”
    That’s rarely true once you render the file.
    Hit the render button, and stop it after a few seconds, then jog through the newly rendered area of still on the timeline and it will look perfect.
  • Winston A. cely
    August 9, 2006 at 12:45 am
    I use Mr. Niles trick all the time, and it works perfectly.
    “If God could do the tricks we can do, He’d be a happy Man.” – Peter O’Toole – “The Stuntman”
    Machine Model: Power Mac G5
    CPU Type: PowerPC G5 (3.0)
    Number Of CPUs: 2
    CPU Speed: 2.5 GHz
    L2 Cache (per CPU): 512 KB
    Memory: 4.5 GB
    Final Cut Studio (Not Universal, yet)
  • Chelsea Womack
    March 3, 2009 at 5:15 pm
    I also have created a text animation template in Motion, and when using the template in FCP, the render time is outrageous. The animation seems simple enough… 6 layers of text that circle around a logo. The render time for a 4:30 video is something like 10 hours of render time! Why does it take so long, and can it be cut down?
    Mac OSX 10.5.5
    2×2.66 GHz Dual-Core Intel Xeon
    4 GB 667 MHz DDR2 FB-DIMM
    Final Cut Studio 2
