Activity › Forums › Maxon Cinema 4D › Want to rotate hair length bitmap
Posted by Sam Murray on August 12, 2015 at 12:12 amHi I’m trying to rotate the hair length bitmap on a sphere, but cannot find any way of doing it. Is there some kind work around or can you rotate the length bitmap?
Sam Murray replied 11 years, 1 month ago 2 Members · 7 Replies -
Brian Jones
August 12, 2015 at 2:08 amuse a Projector shader in the length of the hair mat, put the bitmap in the projector shader and you get the same offset/length etc controls there as you normally get in the material tag.
Sam Murray
August 12, 2015 at 3:39 amDo you mean Material Editor>Length>Effects>”Projector” then add texture because if that’s the case I think I’m doing something wrong or are you talking about something else.
Brian Jones
August 12, 2015 at 3:49 amit sounds like you might be in the right place
in the Hair Mat/Length channel Texture slot choose Effects/Projector (which is what I think you were talking about so, so far so good)
Click on Projector (now that it’s there) and it opens up and presents a new Texture slot where you want to put your image file – the settings below are the ones you would use to offset the image (in effect rotating around the sphere) with lots of additional controls to tweak the position/rotation/size etc. -
Sam Murray
August 12, 2015 at 4:27 amDam I tried that, but Position and Rotation don’t do anything and rotation is the only one that I need.
Brian Jones
August 12, 2015 at 2:22 pmit’s not position and rotation that you want probably, I think you want Offset X but try with a test sphere and the same image in a Projector shader but in the color channel so you can see what’s going on
Brian Jones
August 12, 2015 at 7:35 pmoh yeah, if it is Rotation that you want you don’t see correct results unless you render
Sam Murray
August 12, 2015 at 11:53 pmIs there something that I have to turn on in the render settings because it texture still doesn’t move or rotate?
