Activity › Forums › DVD Authoring › Want to rip my dvd to format that is supported by premiere pro without losing any quality?
Posted by Matthias on December 19, 2005 at 12:39 amI made a film awhile back and i put it on dvd and i now want to rip it to a format that supported by premiere without losing any quality so i can do some color correction?
Doesn’t matter how big the file will be if i rip it. Just whats the best way to do it and Best quality?Matthias replied 20 years, 8 months ago 3 Members · 9 Replies -
Noah Kadner
December 19, 2005 at 5:17 pmYou can certainly rip with any number of commercial, shareware or freeware rippers you’ll find via Google but it’s not possible to reverse the effects of MPEG-2 compression.
Noah
Shvr
December 21, 2005 at 5:28 pmYou are going to lose some quality re-editing this way. But if you must, be sure to frame serve the MPEG files to PPRO as opposed to rendering out an avi then re-editing.
Matthias
December 21, 2005 at 9:10 pmSo I renamed my vob file to a mpg and brought into ppro but its harder to edit than regular captured footage from my cam. How do i fix that and i think when you say frame serve to ppro thats what will fix it but i dont know how to do that. Could you please explain.
Shvr
December 22, 2005 at 6:31 pmWhen I need to edit MPEG in PPRO or AE, here’s how I do it:
I load and select my MPEG (VOB, mpg etc) clips using DGIndex, which is basically DVD2AVI, but creates an index file. Then, I load the index file into VFAPI (the frame server,) which then creates a virtual AVI file. You can then load the AVI into PPRO and edit away.Now, it’s not pefect. It’s a bit slower editing than a real AVI file, but PPRO doesn’t seem to choke on the file, like it does with straight MPEGs.
Frame serving this way, saves you a bit more quality than re-compressing your MPEG file into an AVI with DVD2AVI and editing that way – although that is certainly an option for you if performance in PPRO becomes an issue.
Shvr
December 22, 2005 at 11:04 pmYeah freeware – google both and you should find the downloads:
https://www.google.com/search?sourceid=navclient&ie=UTF-8&rls=GGLD,GGLD:2005-09,GGLD:en&q=dgindex+vfapi -
Matthias
December 22, 2005 at 11:38 pmI downloaded DGMPGDec Version 1.4.6 Beta 2 Executables, is there anything else i need and when i got them what do i do.
Shvr
December 23, 2005 at 4:55 amHere’s VFAPI:
https://www.doom9.org/Soft21/SupportUtils/VFAPIConv-1.05-EN.zipDGindex is pretty straight forward. Open you mpeg, select your clip, save your file, then open that file in VFAPI and you’ll be frameserving.
Matthias
December 23, 2005 at 8:11 pmWhenever i transport the video file out of dgindex and then pull it into vfapi and then make a virtual avi and i pull it into ppro, ppro comes up with an error that says unsupported file type
