Activity Forums Blackmagic Design Want to capture HD quicktimes on PC
  • Want to capture HD quicktimes on PC
    Posted by Accountneedsrealnameupdate on February 21, 2006 at 11:03 pm
    We are capturing from D5 on windows XP and need quicktime files to hand off to another application. From what I’ve read it’s possible to capture ntsc and pal to Quicktime using the Deck Control utility but not HD, is this really the case? (https://www.blackmagic-design.com/support/detail.asp?techID=101)
    If HD quicktime capture is not possible I was wondering if there is any quicker way to convert avi files to quicktime without rendering in after effects or some other application, which is really slow, I know the framelink utility causes avi’s to appear as dpx sequences and vice-versa and was wondering if there is a similar trick with avi’s and .mov’s ie just change the header information or something without rendering every frame.
    Any suggestions? All help is appreciated.
    Glenn Stewart
    1k Studios
    Accountneedsrealnameupdate replied 20 years, 6 months ago 4 Members · 10 Replies
  • 10 Replies
  • Kaspar Kallas
    February 22, 2006 at 5:09 am
    You can capture HD with decklink deck control just fine even if you dont have AGP/PCIe graphics card (in this case you just will not see the live preview on your screen)
    Other thn that you should be all set
    -Kaspar
  • Pentti Kakkori
    February 22, 2006 at 5:18 am
    In windows ou can capture various HD Quicktimes but not compressed PhotoJPG. If you have Blackmagic card, look at Easy setups at DeckContol, there are 18 different HDTV setups, all are quicktime. At the moment DeckControl captures only Quicktimes. But Quicktime to dpx, no, I miss it too.
  • Kaspar Kallas
    February 22, 2006 at 10:36 am
    you can mount your qucktime file as dpx seequence with framelink
    -Kaspar
  • Accountneedsrealnameupdate
    February 22, 2006 at 6:52 pm
    Great news!!
    Thanks guys.
    Glenn Stewart
    1k Studios
  • Pentti Kakkori
    February 23, 2006 at 8:11 am
    Hi Kaspar
    Can you mount QT-movies to dpx files in Mac? In PC only avis seems to be mountable. I didn’t find anything about Framelink in Blackmagic new manual (jan 2006).
    pena
  • Kaspar Kallas
    February 23, 2006 at 11:45 am
    hmm to think of it I have not tried the frame link on win machine – on mac it works fine on quicktime
    Unfortunatly I do not have a PC workstation anymore so cannot confirm or daeny anything
    -Kaspar
    February 23, 2006 at 6:55 pm
    I wasn’t able to mount quicktimes as dpx on the PC, actually I wasn’t able to mount avi’s either but at least it seemed to start the process with them before giving a “Try again later” error. The manual is pretty vague about the Framelink application, at first I thought it didn’t need to convert anything, just tricked the system into seeing individual frames instead of a video file but after playing with it a bit it seems closer to making an image sequence into a quicktime and saving as a reference movie, anyone know what I mean? If I could get it to work I might understand it better.
    Glenn Stewart
    1k Studios
  • Adrian Hauser
    February 28, 2006 at 10:57 am
    I tried the Framelink AVI to DPX mode on a PC and it worked quite well.
    However I would not try to do this to long AVI sequences because when you mount the
    DPX disk and begin to read the frames in another application what you are actually doing is create a bunch of new frames in a temp folder (see settings or preferences). So if you want to read 20 mins of DPX frames you
    will end up quickly creating another few hundred GIG (in HD) of data on your drives.
    The application seems to be really useful when working with single shots not so much for longer form work.
    I spoke to BMD about this and they thought they could get the frames being written to the temp folder to inteligently cache only x amount of frames around the currently read frame. IE frames outside that area would
    automatically be deleted. I dont know how far they got with this.
    It would be really cool if they could just capture Image sequences DPX TGA TIFF OpenEXR direct.
    I might try and start a poll to see how many people are interested in this.
    Adrian
  • Kaspar Kallas
    February 28, 2006 at 11:05 am
    you have at least one vote!
    -Kaspar
    February 28, 2006 at 6:34 pm
    Amazing!! Just yesterday in our place we were discussing how nice it would be to capture straight to dpx!! I think the bluefish cards can do it and that’s what made us think of it. Transcoding is such a pain!!
    Glenn Stewart
    1k studios
