Activity › Forums › Apple Final Cut Pro Legacy › Walter Biscardi I`m stuck pls help!
Walter Biscardi
June 4, 2007 at 9:30 am[Antonio Atzei] “Can I just make sure that I understood right?
I right click from FCP on the sequence where all my assets are then send to compressor….
grazie”That’s one way to do it. I export a Reference Movie from FCP and then bring that into Compressor. I don’t use the “Send to Compressor” command as I feel that’s a slower way to compress with FCP running in the background.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Alexander Kallas
June 4, 2007 at 10:54 am[Antonio Atzei] ” I also tried a self contained but with the same result.
ciao
Antonio”So how exactly did you create this, hopefully not with QuickTime conversion which results in re-compression.
IMHO direct from FCP can produce what you are seeing, which is really a gamma change.
Be sure to try export>QuickTime movie, and feed that to compressor.
Let us know.Cheers
Alexander -
Antonio Atzei
June 4, 2007 at 12:46 pmAlexander
My first attempt was to export from FCP a HDV timeline to compressor and the result was gr8 in regards definition, as stated b4 the light on the dvd was doubled to say the least….. I`m sure that I`ll try also yor suggestion.
Thanking you for your help
ciao
Antonio AtzeiBABALOTTI PRODUCTIONS
SYDNEY
POWER MAC G5 QUAD SYSTEM
5.5GB RAM
1 TB OF MEMORY.FCStudio -
Ron James
June 16, 2007 at 4:05 pmI think you need to widen your search. Extend the dates. I’m just the one that wanted to investigate it and I actually resent your insinuation here.
First of all, it’s Bob Hudson that discussed this the most. Remember him?
Try a new search and stop trying to turn my comments into “criticism” for the sake of argument.
What is my criticism exactly?
