Activity Forums Apple OS X wallpaper start up
  • wallpaper start up
    Posted by Jose Alfonzo on March 21, 2006 at 9:35 pm
    I need to put the company’s logo as a wallpaper where you get to use the user of the computer. Example: computer starts up, you see the apple, then loads, and you have an option of which user you want to use… I need the logo there (as a wallpaper) any one knows how to do that? Thank you.
    Jose Alfonzo.
    Curtis Thompson replied 20 years, 6 months ago 2 Members · 1 Reply
  • Curtis Thompson
    March 22, 2006 at 2:38 am
    hello…
    i believe that there are a few apps out there that will help you hack this (i.e. there’s no os x setting for it) – you could try version tracker for that…
    however, the low-budget way to pull it off is to put your desired wallpaper into /Library/Desktop Pictures and rename it to “Aqua Blue.jpg” (i.e. replace the one that’s there) – it would eliminate that original wallpaper as an option, but since that’s the one used on that login screen, it will make your wallpaper the one that is there…
    sitruc
