Activity Forums Maxon Cinema 4D wall creation
  • wall creation
    Posted by Chris Lee on January 30, 2010 at 3:12 pm
    is there anyway to take a wall, that has been created by a cube, break it into segments, and the break each segment into its on indvidual cube. I am trying to animate a wall being constructed by bricks. But i want to create a special structure, and then slice it into segments, and then cut into bricks
    Greatly Appreciated
    Randy Johnson replied 16 years, 7 months ago 2 Members · 1 Reply
  • Randy Johnson
    January 30, 2010 at 3:22 pm
    I think building it with a single cube and using the Cloner Object is really the way to go here.
    I guess you could build ythe struktyure slice it up and use the fracture object in the Explode Segments & Connect mode would get that to work too.
    /randy
