Activity Forums Adobe After Effects Walking Through Walls
  • Walking Through Walls
    Posted by Tony Kloiber on September 22, 2005 at 2:12 pm
    I’m looking for ideas on how to have an actor walk through a wall.
    Some of the parameters are:
    Low light scene (in a factory at night)
    Actor must walk through wall and then lean back through give a line of dialog and then disappear back through the wall again.
    I will only be using After Effects (no 3D models)
    It might be possiable to do this in-camera with a mirror (pepper’s ghost) but I’m not sure it will work and there’s no adjustments in post with this way.
    TYIA
    Tony
    Tony Kloiber replied 21 years ago 2 Members · 4 Replies
  • Andrew Kramer
    September 22, 2005 at 3:37 pm
    Is your shot locked off (on a tripod)? Is it just a ghost fade, or somehow magical.
    If the shot is locked off you could probably dumplicate the part of the wall tha he enters, and overlay it over where he goes through.
    Just feather the edges of the wall where he would intercept. You can also use masks to follow and round the edges of the intercepting parts like his hands and body.
    Good luck.
  • Tony Kloiber
    September 22, 2005 at 3:52 pm
    Yes probably locked off. Not sure about how you envision the duplicated section of wall. Some of how the effect happens will depend on the camera angle to the wall and how wide the shot is – don’t know that yet.
    I’m guessing that if you pasted a section of bkg over the forgnd, that the scale would be off (i.e. he/she would be bigger than they should be at the point they pass through the wall) because they physically have to be some distance from the wall in the shooting process.
    There is the green screen and matting/roto route but I was looking for a way where I didn’t need to do that for each time the effect happens.
    Thanks for your input.
    TonyTony
  • Andrew Kramer
    September 23, 2005 at 12:12 am
    Basically what I was suggesting is you have a wall on the right and a person on the left walking to the wall for example. Make a freeze frame of the shot where the right wall is not obscured. Then overlay that over the footage with a linear wipe and a feather that cuts off just about where he intercects the wall and then his plate should seem to disappear underneath the piece of wall.
    It’s not ILM but it should get you started.
    Does this make sense?
    Andrew
  • Tony Kloiber
    September 23, 2005 at 5:50 pm
    Yes, I will test that I just think that it might seem as if he is at the wrong scale.
    Thanks.
    TonyTony
