Activity Forums Adobe After Effects Walking through walls in AE
  • Walking through walls in AE
    Posted by Benjamin Tattersley on March 1, 2008 at 9:37 am
    I have some footage of myslef against a greenscreen, walking towards the camera, and a still image of the wall of my house, facing directly towards the camera. I have created a quick opacity boost and added a ripple to the wall, but it still looks awful. Any tips on how to acheive the look whereby some parts of my body come through earlier than others, without using masks?
    Yours gratefully, Ben Tattersley
    Benjamin Tattersley replied 18 years, 6 months ago 3 Members · 3 Replies
  • Graham Quince
    March 1, 2008 at 5:37 pm
    The easiest way I can think of is an animated mask. draw a mask around the foremost parts of your body then set a keyframe and a few frames latter increase the area within the mask. it’s a little complex to explain, but it is pretty easy to achieve.
    Graham
    https://www.shiveringcactus.bravehost.com – Free FX for amateur films
  • Joe Moya
    March 1, 2008 at 6:29 pm
    The only good way I have been able to achieve this effect with accuracy is through rotoscoping… which means it will not be easy.
    Of course like any rotoscoping… it is best you do not have moving legs included in the screen if you do not want to make a difficult process more difficult… or, you could just use MOCHA (…not MOCHA plug-in for AE) for rotoscoping and most of your rotoscoping problems have been solved.
    Joe Moya
  • Benjamin Tattersley
    March 1, 2008 at 6:31 pm
    Much appreciated then, i tried this method, then added a matte choker, duplicating it and finally adding a stroke on the centre parts and using that as a displacement matte (putting a neutral gray backgorund at 50% Opacity on top beforehand) for the wall layer.
