Activity Forums Adobe After Effects Expressions Walk cycle speed
  • Posted by Sean Kimber on February 5, 2016 at 3:32 pm
    I’m trying to create a walk cycle and have measured the amount the x should move for each step. The problem I’m having is I can’t figure out how to make that speed work throughout the rest of the animation. I’ve used “loopOut(“continue)” but since there are ease keyframes on the steps, the character slides a little bit. But if I put eases on my x position keyframes, the character stops and won’t move anymore. How do I account for the ease keyframes and not have my character slide or stop?
    loopOut("continue")
    Sean Kimber replied 10 years, 7 months ago 2 Members · 2 Replies
  • Miguel De mendoza
    February 8, 2016 at 10:21 am
    Maybe do you need to use a “cycle” loop:
    loopOut("cycle",0)
  • Sean Kimber
    February 21, 2016 at 3:06 pm
    Thanks for your help! That didn’t work for me, unfortunately. But I did finally find the answer. When I substituted “offset” for “continue” it honored the ease of the keyframes.
