Activity › Forums › Adobe After Effects › wake behind surfers
  • wake behind surfers
    Posted by Heather Crank on January 11, 2010 at 8:41 pm
    Hello Everyone,
    I’m trying to create a wake behind lots of different surboarders that follows them as they glide across the ocean. The ocean is a flat surface with a ramp (the client doesn’t want a realistic ocean). Is it better to do this with lines and a mask, or is there a better way?
    H
    Heather Crank replied 16 years, 8 months ago 2 Members · 3 Replies
  • Heather Crank
    January 11, 2010 at 9:24 pm
    thanks! Yah, that’s what I thought!
  • David Bogie
    January 11, 2010 at 11:51 pm
    WaveWorld.
    It’s completely awesome for this stuff but it’s not like you just pop it open and apply it.
    You will use WaveWorld to create a grayscale map and pull that into Colorama or some other tint filter.
    You will create one Waveworld output for each surfer and then use blend modes to combine them all into a precomp that will be passed on to Colorama.
    bogiesan
  • Heather Crank
    January 11, 2010 at 11:52 pm
    Hey Thanks Bogiesan,
    I”l give that a shot too!
    H
