Activity Forums Adobe Premiere Pro vx1000-century16x9-premiere workflow…is this correct?
  • vx1000-century16x9-premiere workflow…is this correct?
    Posted by Paul Bolden on July 7, 2009 at 8:12 pm
    Hello everyone,
    Am I understanding this correctly?
    First, the rectangular shape of the Century 16X9 lens is attached to the vx1000 vertically where the rectangle looks like a door opposed to horizontally as on Hi Def cameras. Am I right on this?
    The resulting video is a squeezed 4×3.
    Then in premiere 1.5…I set the project to dv ntsc widescreen 16×9. I then select interpret footage and then under pixel aspect ratio select conform to d/dv ntsc widescreen 16×9 (1.2). Correct?
    The resulting video renders out nicely, correctly filling premiere’s monitor and a HDTV monitor with what appears to be the correct aspect ratio.
    Can someone tell me if this is the correct workflow? When I look at the rendered clip’s preferences it lists the frame size of 720×480 and not for example 1280×720
    Paul
    Brian Louis replied 17 years, 2 months ago 2 Members · 3 Replies
  • Brian Louis
    July 8, 2009 at 12:28 am
    [paul bolden] “it lists the frame size of 720×480 and not for example 1280×720”
    Widescreen NTSC SD is 720×480 with anamorphic PAR of 1.2, the square pixel count for wide screen is approx 860×480 usually in displays or some camcorder imaging chips which is DSPed to the anamorphic 720×480, 1280×720 is HD
  • Paul Bolden
    July 9, 2009 at 8:54 am
    Thanks Brian, I think I finally get it. The anamorphic image 16×9 (1.2) is actually compressed into a 4×3 .9 aspect ratio normal for dv ntsc and this is why the images look squashed on a 4×3 timeline. When the clip is placed on a 16×9 timeline the image expands from a .9 to a 1.2 aspect ratio providing a correctly proportioned widescreen experience.
    Paul Bolden
  • Brian Louis
    July 9, 2009 at 4:46 pm
    You got it, thats why the long axis is vertical on a anamorphic lens, its distorting the wide image to fit on the SD PAR
