VST panel missing
Greetings!
I`ve been trying to load some VST plugins in Adobe Audition 3. I did it all up to refreshing effects list, locating and enabling them(so far so good) but when I go in Multitrack view and press Fx in the sequencing panel and try to load an VST effect in a certain channel, I can see that the VST section from the dropdown menu is missing! Just as if it has been cut….
Any suggestions on this one?>
Thanks a lot!
G
