Activity Forums Adobe Audition VST Effect Missing on Mixdown (Audition CS6)
  • VST Effect Missing on Mixdown (Audition CS6)
    Posted by Sean Perkins on December 18, 2014 at 7:15 am
    I have a VST plugin set up in Audition CS6 specifically for sidechain compression. During software playback, the effect works perfectly, but it’s completely absent on the exported mixdown file.
    I emailed the plugin creator in July about the issue and received this response: “The solution to this in other host programs is to select the ‘realtime export’ option or similar. I’m not sure if Adobe has this feature.” A new version of the plugin was recently released, but still has the same problem. I can’t find a realtime export option in Audition, but this VST plugin did work properly in Audition 3 before I upgraded to CS6.
    Can someone please help me out with this?
    Sean Perkins replied 11 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
