Activity Forums DVD Authoring VSO & Audio/Video Sync issues
  • VSO & Audio/Video Sync issues
    Posted by Ryan Vick on July 30, 2009 at 5:32 pm
    Hi, I’m a novice DV/Firewire user who is trying to transfer DV
    recordings from DV cassettes using a ADS Tech Pyro 1394
    PCMCIA card and a Startech Firewire/DV end cable to the
    harddrive, using Microsoft Windows software Movie Maker
    Pro.
    I’m limiting the captures to 3 video choices, DV-AVI,
    “high quality video (ntsc)” and “high quality video (large)”.
    The source video was filmed straight to DV cassettes at
    LP or SP mode on a JVC DV camcorder (model #GR-D770U)
    I’m using VSO Convert X to DVD to make the DVD files
    (vob) from the avi/wma files that Microsoft Windows Movie
    Maker made on a laptop with plenty of
    HD space and with no other tasks/software running.
    I’ve been playing the VOB files (dvd) from the harddrive that
    VSO made using VLC Media Player, to test the dvd before
    I burn a dvd. This is where the problem is. The DV-AVI
    file on the menu plays ok, but I can’t make 212 mb files from
    1 min of video. The “high quality video (ntsc)” video is not
    syncing with the voices, and none of the other ones are.
    I just checked the source files, and they’re good. No sync problem.
    I play the “high quality video (ntsc)” file from it’s original file,
    a .WMA file, and it’s good, no sync problem.
    When the test works, I’ll use Verbatim discs.
    (Ultra DMA 2 is enabled)
    Obviously, the sync problem is introduced from VSO.
    What’s going on? Is this a problem with a specific version
    of VSO? Is there a setting I missed or need to change?
    The PCMCIA card came with Video Studio 9.
    Have you had this problem? What software do you use – or
    would you use?
    Maybe one of you can recommend a better capture software
    or dvd making software than what I’m using.
    What should I use instead of VSO?
    Ryan Vick replied 17 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
