Activity Forums Maxon Cinema 4D VRAY Twitchy render problem
  • Jeremy Grubaugh
    February 15, 2009 at 12:34 am
    So I created the effect I wanted using non TP particles — im simply using the cinema 4d default particles system. Well, no luck. Now it’s giving me a whole new problem when rendered through the camera. The particles are not jittery/shaky but they simply do not produce and animate like they are suppose to. Case and point…
    Before Camera: Correctly renders through editor
    https://fluidresolution.com/NoneTP_Editorview.mov
    After Camera: incorrectly renders through camera
    https://fluidresolution.com/NoneTP_Cameraview.mov
    scene file
    https://fluidresolution.com/ImagePArticles2.zip
    I am starting to think that C4d + Vray + Particles + Camera = no worky. This is a riddle wrapped in an enigma placed in the center of a maze.
    I didn’t like cheeseburger alley cats near me!
  • Brian Jarrett
    July 14, 2009 at 9:25 pm
    I just came across this issues as well. It seems odd that vray would change how particles would animate. Have you found a solution to this problem?
