Activity Forums Maxon Cinema 4D Vray Self-illuminating an object
  • Vray Self-illuminating an object
    Posted by John Orchard on July 3, 2012 at 1:22 am
    Help! I’m VERY new to Vray and I can create a scene and create vray materials and lights, but I cannot seem to create a luminosity material that when applied to an object, acts as a light in the scene. In the Vray Advanced Material, I figured that it is what the ‘luminosity layer’ does, but it seems to not work. All my render settings are fine (I suspect, as everything else in the scene renders as expected). I tried adding a VrayLight tag to the object and that didn’t work either. Please help!
    John
    Adam Trachtenberg replied 14 years, 2 months ago 2 Members · 5 Replies
  • Adam Trachtenberg
    July 4, 2012 at 2:34 pm
    Do you have global illumination turned on in VRay? Otherwise it won’t work.
  • John Orchard
    July 5, 2012 at 5:11 pm
    Global illumination is turned on. Man I can’t figure out what I’m doing wrong. I’ve been searching for tutorials all over the net and I can’t seem to find what I’m looking for.
  • Adam Trachtenberg
    July 5, 2012 at 7:03 pm
    You mean global illumination is turned on in the vRay render settings, right? Not Cinema’s separate GI effect?
    If so it should work. If you post a simple scene I’d be happy to take a look.
  • John Orchard
    July 6, 2012 at 12:27 am
    Can you NOT apply an illuminance layer to a 2D object, like a plane, because that’s what I’m doing. As soon as I applied the material to a 3D object, it worked!
  • Adam Trachtenberg
    July 6, 2012 at 2:59 am
    One thing about vRay is that it’s sensitive to normal direction. So if you put a luminous material on a plane, it will only emit light from the side with the polygon normals facing out.
    Example: 4374_vrayluminous.c4d.zip
