Activity Forums Maxon Cinema 4D Vray Multipass taking significantly 20x longer than ‘Regular Image’ render with same output settings
  • Vray Multipass taking significantly 20x longer than ‘Regular Image’ render with same output settings
    Posted by Ryan Ainge on September 9, 2014 at 10:19 am
    I’ve attached a simplified scene of the one I’m working on. Everything has been great up to this point with vray and my test renders, but once I added multipass, everything slowed down by a huge margin. My renders went from taking 15 seconds to over 3 minutes per frame.
    I checked all my settings, restarted cinema, tried new project files, disabling/enabling things, and couldn’t put my finger on it. Does vray just take that much longer when rendering out multipasses? I don’t see this problem anywhere else dealing with this on my google searches.
    I don’t understand why it would take that much longer rendering the EXACT same image with same settings, just with multipass on.
    download:
    7960_asd.c4d.zip
    Lisa Schmölzer replied 11 years, 9 months ago 2 Members · 1 Reply
  • Lisa Schmölzer
    December 22, 2014 at 2:09 pm
    Hi Ryan,
    I’m just experiencing the exact same thing! Did you ever solve your problem?
    Cheers, Lisa
