Activity Forums Maxon Cinema 4D VR Rendering
  • VR Rendering
    Posted by Dave Montague on December 15, 2005 at 8:44 pm
    Has anyone set up a Object VR in C4d that allows you to drop in a product and simply hit render and output as indiviual frames? The VR rendering that C4d offers is not accurate…they admitted this to me. When you do a VR using the built in render settings, the light moves with your object and there is no way to stop that from happening. Maxon and I have had discussions about it and finally they agreed that the lights would not move with the object in real life. The object would rotate with the lights fixed. Anyway, to do it right you have to do it manually.
    Thank you,
    Dave
    Adamt replied 20 years, 8 months ago 2 Members · 1 Reply
  • Adamt
    December 16, 2005 at 5:01 am
    Not sure what you mean. If you set up lights in your scene they won’t rotate with the camera. That’ll only happen if you use the autolight.
