Activity › Forums › Adobe Premiere Pro › VR problem with 2D Green Screen subject
  • VR problem with 2D Green Screen subject
    Posted by Tolu Exmore on January 2, 2018 at 10:50 pm
    Hello,
    Wondering if anyone has come across this problem and any potential fixes.
    I filmed a 2D subject on green screen to include them in a VR environment. I shot on a Blackmagic camera in 4K. I have tried several workflows to include the person into the scene, but looking through Vive goggles, they end up looking a bit blurry and their edges looked jagged. The problem seems to happen only when I apply the Skybox Project 2D effect on them. As soon as I put that effect on my keyed footage, the edges look jagged as opposed to without it.
    Here is the details of my most recent workflow; I key the original footage in after effects -> dynamically link and bring into Premiere -> Apply and position with Project 2D. I tried a different workflow where I applied and positioned the effect in after effects and then dynamically linking into Premiere, but I got the same results…jagged edge lines.
    The final output for this is to be viewed through a headset. Working on a Mac Pro 3.5 GHz.
    Any suggestions?
    Tolu Exmore replied 8 years, 8 months ago 2 Members · 4 Replies
  • Tolu Exmore
    January 3, 2018 at 5:30 pm
    Thanks! Will try it out and see if that helps
  • Tolu Exmore
    January 4, 2018 at 4:21 pm
    Thanks again for the suggestion Dave, but doesn’t seem to work. I get the same jagged edge. Going to try another possible workaround
  • Mike Sevigny
    January 25, 2018 at 2:48 pm
    Hey Tolu,
    This is actually a common problem in 360 and is based on several factors.
    I explain what’s happening and how to fix it in this tutorial [@ 36:52]:
    https://vimeo.com/222523621
    Hope this helps
    Mike Sevigny
    CTO – Torus Media Labs
    https://www.torusmedialabs.com/
  • Tolu Exmore
    January 29, 2018 at 6:02 pm
    Thanks! Will try this out.
