Activity Forums Adobe After Effects VR 6PACK : render with spherical camera?
  • VR 6PACK : render with spherical camera?
    Posted by Peter Timberlake on March 1, 2017 at 5:27 am
    Hey!
    So I’ve been able to set up ‘6pack’ in the 3D environment of AE (which is essentially just a cube with a 360 environment plastered on each of the 6 planes of the cube). Is there any way I can either:
    1. render that cube with a ‘spherical’ camera (or a camera whose lens has a 360 degree field of view)?
    OR:
    2. warp those 6 images in a mathematically predictable way…especially taking alpha channels into consideration? like, this could be done in a somewhat crude way with re:vision’s uv plugin, but I specifically want to avoid using non-stock-ae plugs.
    3. I’m sure someone out there has hacked this in a third way?
    thank you!
    Walter Soyka replied 9 years, 6 months ago 2 Members · 1 Reply
