Activity Forums VEGAS Pro VP18 won’t import wav file
  • VP18 won’t import wav file
    Posted by James Williams on February 13, 2021 at 1:40 am
    What am I missing? I’ve been using Vegas for years. It won’t take a .wav file on the timeline. How do I make it happen. TIA
    Dan Bridges replied 5 years, 7 months ago 4 Members · 3 Replies
  • Setiawan Kartawidjaja
    February 13, 2021 at 2:08 am
    VEGAS Pro version and build?
    have you try full resetting and delete cache ? (hold Ctrl+Shift while running VEGAS Pro until dialog box appear and checkmark to delete cache)
  • Red-rob Rothkopf
    February 13, 2021 at 3:41 am
    Is your problem with a specific .wav file or any wave file? Have you tried another file you know works ok?
  • Dan Bridges
    February 13, 2021 at 6:53 am
    Perhaps the Wav is in a unusual format (24-bit, Big-Endian). Open it in MediaInfo (https://mediaarea.net/en/MediaInfo/Download – when you first run it it will offer to become a r.click option in Windows File Explorer – very convenient) and report back. Here’s the Text-format report for a typical Signed 16-bit Little-Endian Wav file :
    General
    Complete name : D:\Testfile.wav
    Format : Wave
    File size : 252 MiB
    Duration : 22 min 55 s
    Overall bit rate mode : Constant
    Overall bit rate : 1 536 kb/s
    Writing application : Lavf58.42.100
    Audio
    Format : PCM
    Format settings : Little / Signed
    Codec ID : 1
    Bit rate mode : Constant
    Bit rate : 1 536 kb/s
    Channel(s) : 2 channels
    Sampling rate : 48.0 kHz
    Bit depth : 16 bits
    Stream size : 252 MiB (100%)
