Activity Forums VEGAS Pro VP16 : Cannot import mp4 video with mp3 audio but I can import a standalone .mp3
  • VP16 : Cannot import mp4 video with mp3 audio but I can import a standalone .mp3
    Posted by Cedric Divang on February 11, 2021 at 6:03 am
    Hello, I cannot import an mp4 video having mp3 as audio track (I get the error “The file is most likely corrupted or of an unknown format”) but I can import a standalone .mp3 file or a mp4 having no audio or having AAC audio.
    As a workaround, I extract the video and audio tracks and import them separately but it’s not a viable solution.
    Please help : – (
    Here’s an example MediaInfo of a vidéo I cannot open :
    _______________________________________________________________________________________________________________________________
    General
    Complete name : I:\VEGAS\[Tennis EN] Masters de Madrid 2017 (Quart de Finale), Rafael Nadal vs David Goffin, MULTITRACK, SKYSPORT HD [DE] [25i]-HB.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42 (isom/iso2/avc1/mp41)
    File size : 33.6 GiB
    Duration : 1 h 35 min
    Overall bit rate mode : Constant
    Overall bit rate : 50.1 Mb/s
    Encoded date : UTC 2021-02-11 05:06:34
    Tagged date : UTC 2021-02-11 05:06:34
    Writing application : HandBrake 1.3.3 2020061300
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : Main@L5
    Format settings : CABAC / 3 Ref Frames
    Format settings, CABAC : Yes
    Format settings, Reference frames : 3 frames
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Bit rate mode : Constant
    Bit rate : 50.0 Mb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 50.000 FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.482
    Stream size : 33.5 GiB (100%)
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Codec configuration box : avcC
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 3
    Format settings : Joint stereo / MS Stereo
    Codec ID : mp4a-6B
    Bit rate : 128 kb/s
    Channel(s) : 2 channels
    Sampling rate : 48.0 kHz
    Compression mode : Lossy
    Stream size : 87.8 MiB (0%)
    Title : Stereo
    Default : Yes
    Alternate group : 1
    Cedric Divang replied 5 years, 6 months ago 2 Members · 2 Replies
  • Setiawan Kartawidjaja
    February 11, 2021 at 6:24 am
    Usually MP4 video contains video stream AVC and audio stream AAC.
    For this type Video AVC and audio MP3 is not a wide-standard.
    Transcode it.
  • Cedric Divang
    February 11, 2021 at 6:39 am
    Thanks for your quick reply Setiawan but I’d rather not transcode the audio part in AAC (loss of quality) just to be able to open the video in Vegas. Isn’t there another solution ? Extracting the tracks to open them separately on Vegas is what I currently do but it’s a very tedious task if I have to do it every time.
    PS : Although the video is not standard, I am able to play it without any problem on VLC or MPC-HC.
