Activity Forums Maxon Cinema 4D Voronoi Multiple Objects
  • Voronoi Multiple Objects
    Posted by Spencer Rand on October 27, 2020 at 1:54 pm
    Hi Guys,
    Does anyone know how a project like this is cut up?
    https://vimeo.com/120460203
    It looks like a vornoi fracture of the whole scene but I can’t seem to get multiple objects to join as blocks like this. I have been trying putting multiple objects under a boolean, fracture or connect object. Any thoughts? So far it seems they recommend using the connect and delete function but that kills any animated elements.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Michael Szalapski replied 5 years, 10 months ago 2 Members · 1 Reply
  • Michael Szalapski
    October 27, 2020 at 3:17 pm
    If you go frame by frame, you’ll notice that all of the animated elements transition out over one frame before the transitions happen. Like, there’s a quick, one-frame fade out of the trucks/boats/etc. before the cubes start flipping. And the cubes are actually disappearing. It looks almost like Transform from GSG is being used.
