Activity Forums Maxon Cinema 4D Voronoi fracture not working properly. Help?
  • Voronoi fracture not working properly. Help?
    Posted by Renu Sharma on August 1, 2021 at 2:49 am
    Hey folks! I am 4 days into learning C4D and trying out voronoi fracture. The first problem is, the tag needs to be applied to both voronoi and the object (child) separately for it to work at all. Otherwise the object just falls through the plane intact and becomes invisible even though I can see the point for it under the plane. The fragments are falling through the plane/floor and not landing. They’re also exploding too far and wide. What am I doing wrong?
    Using C4d R21
    Jim Scott replied 5 years ago 2 Members · 1 Reply
  • Jim Scott
    August 1, 2021 at 5:37 pm
    If you’re just trying to drop a fractured object on to a plane and have it break apart on impact, your setup should like the one below. If that doesn’t help, please upload your project file.
