Activity Forums Maxon Cinema 4D Voronoi fracture distorting objects
  • Voronoi fracture distorting objects
    Posted by Tarn Mount on July 4, 2018 at 11:33 am
    Hi guys,
    I’m creating a chocolate bar of sorts with small nuts on it. I intend to smash it using voronoi fracture. But when I drop the model into the voronoi fracture the small nuts drastically distort. Everything i the scene has been converted to an object. I’m a noob to C4D – can anyone tell me what’s going wrong?
    I have attached 2 images (hopefully) – one to show what it looks like before dropping into VF and the second to show what happens once I do.
    Cheers, Tarn
    Tarn Mount replied 8 years, 1 month ago 3 Members · 3 Replies
  • Brian Jones
    July 4, 2018 at 2:42 pm
    haven’t ever seen that, unless someone has and knows what’s going on I would need to see how it’s made (the scene file might be needed)
  • Benjamin Priddle
    July 4, 2018 at 3:47 pm
    This one stumped me for a moment, but I think what you need to do before putting it in the Voronoi fracture is use the boole tool to merge all the objects together properly.
    Using the boole tool with the connect tool, you can merge all your objects into a fused object – “Boolean Type – A Union B”
    If you then make the boole editable
    Then select the new group including everything a child within that group and “connect objects and delete”
    Lastly, you’ll need to select your new single object in point mode and “optimize” the mesh
    This is now you’re fused object. When you throw that in Voronoi fracture it will actually brake the model like a broken chocolate bar as the nuts are part of the model rather than “grouped” with the object.
    I hope that makes sense?
  • Tarn Mount
    July 5, 2018 at 2:42 pm
    Thanks heaps. I think that might work. But there are currently too many polygons making my nuts so my poor laptop is suffering. so I need to sort that problem out first then see if it all works. Thanks or taking the time to help out!
