Activity Forums Maxon Cinema 4D Voronoi fracture and gravity
  • Voronoi fracture and gravity
    Posted by Danny Perez-triana on July 1, 2020 at 8:57 pm
    hey everybody, I’m trying to shatter a circular window with the Voronoi fracture (I’m in R18).
    I’m using a sphere as a rigid body and then having that smash through the window (also set to rigid body).
    but whenever I animate the sphere to pass through the window it will do one of two things:
    1) If I set the force tab within the dynamics tag of the sphere to 100 in the FOLLOW POSITION: the sphere will pass through BUT wiggle and the pieces falling off seem to wiggle strangely rather than just explode out and fall after initial impact.
    * I have set the gravity to zero so I can have the window set in place.
    If I don’t set the follow position to 100 and leave it at zero, the sphere travels very very slowly and definitely doesn’t travel within the keyframes I’ve recorded, ie takes a really long time.
    I tried going through the dynamics tags to see if there was anything I could work with there but didn’t get anywhere.
    any advice appreciated, hope everyone is well and safe
    thanks
    Ignacio
    PROJECT FILE: 14207_vrfr1.c4d.zip
    Danny Perez-triana replied 6 years, 2 months ago 2 Members · 2 Replies
  • Brian Jones
    July 1, 2020 at 11:37 pm
    The sphere should have a Collision tag on it, that will be animatable without having to use follow position etc. For the window you can animate the gravity to turn on at impact or put the window in a frame that is a Collider to hold it until it’s hit
  • Danny Perez-triana
    July 2, 2020 at 12:24 am
    wonderful, thanks!
    makes sense,
    Ignacio
    dip
