Activity › Forums › Adobe After Effects › volumetric light in effect
Posted by Elsamaria on September 11, 2006 at 4:42 pmI would like to know where can I find the plugin for volumetric light in After Effects… Whats its name and if I can get it for free some where…
Thanks.Darren Gardner replied 20 years ago 6 Members · 7 Replies -
Nicholas Toth
September 11, 2006 at 5:11 pm -
Mike Clasby
September 11, 2006 at 5:37 pmLux is the slick way to go, but here is the only alternative to I know of.
https://www.petertorpey.com/tutorials/volume_light/
Click on the link at the bottom of the page, the second to last sentence is the “Download the script” link. Put the .jsx file into the AE Scripts Folder. An earlier user of this had rendering problems,
https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=2&postid=886154
when he copied the Script Text file with his Safari using “Copy File”, he got “funny little text objects” between each line of the expressions, when he deleted these everything was OK. I just downloaded the .jsx like I said and all was fine.
This is the only soution I know of for the Luxless.
Ron Lindeboom
September 11, 2006 at 9:50 pmWe remove any and all posts that have to do with pirate software and so if that was what you were referring to by your “is there somewhere I can download it for free” remark, you will find no help here to do things like that.
Regards,
Ron Lindeboom
Darren Gardner
September 15, 2006 at 7:01 pmI tried out the tutorial for volumetric lighting found on http://www.petertorpey.com and rendered out the end product and it looked great. Then I modified the position of “light 1” and “Light 1 POI”, by setting them back into Z space and mapped out a sweeping camera move in which the volumetric light moves in and out of frame as the camera tracks another object.
Here’s the problem: When I render it out, After Effects freezes up. So, I did a number of test renders excluding different layers to try and find the problem layer. It turns out its the Lens Flare that’s causing the crash, but I’m not sure why its causing the crash or how to fix it. My hunch is, it has something to do with the ‘.toComp([0,0,0])’ part of the expression applied to Flare Center. Any suggestions would really help. Thanks!
