Activity Forums Maxon Cinema 4D Volumetric light cut off?
  • Volumetric light cut off?
    Posted by Justin Hall on August 30, 2015 at 8:52 pm
    G’day guys, I have come across an issue… I have decided to make an animation within a room, it contains a volumetric/visible light as the main one, i noticed as i was going through the frames, the vol./vis. light is chopped in half, and eventually dissappears at the end… any ideas on how to fix?
    9192_untitled.png.zip
    Jordan Quackenbush replied 11 years ago 2 Members · 1 Reply
  • Jordan Quackenbush
    September 2, 2015 at 9:30 pm
    Can you attach/link the scene file?
    Jordan Q
    If I’m posting a question, it means I’ve Googled it for far too long and couldn’t find a solution/answer.
