Activity Forums Adobe Premiere Pro volume of my audio
  • volume of my audio
    Posted by Ryan Santos on June 25, 2010 at 7:29 am
    How should I adjust my audio? I see that there is a reference at the right side of Premiere Pro’s screen but I don’t know what level should my audio go/ peak. Hope someone can help. God bless!
    Angelo Lorenzo replied 16 years, 1 month ago 4 Members · 3 Replies
  • Jeff Pulera
    June 25, 2010 at 6:09 pm
    Hi Ryan,
    I think in general that keeping the audio to about -6dB is pretty much a standard setting to go by
    Jeff Pulera
    Safe Harbor Computers
  • Clyde Villegas
    June 26, 2010 at 4:05 pm
    -6db is the peak?
  • Angelo Lorenzo
    August 4, 2010 at 2:23 am
    It’s a bit science and a bit art. I also suggest running talking voices at -6 (usually with some soft compression like 2.5:1 to even out the peaks) because if you add foley or background music, it’ll have enough headroom so the meters don’t peak at 0db (remember waves add together and amplify, so that’s why low background music will still raise the db level). It’s a pretty decent rule of thumb for dialog scenes and interviews, but it’s open to interpretation.
    Of course, you should always record as hot (loud) as possible and then mix down to whatever volume you’re using, since this will increase the signal to noise ratio and result in a cleaner recording.
