Activity Forums Adobe Audition volume level
  • volume level
    Posted by Ebarfield on May 25, 2006 at 2:31 pm
    Hello:
    I video-taped a musical (actually, I was singing in the choir and a friend ran my camera), which had interludes with speakers giving short testimonies. The audio track is “up” and “down” in a number of places — very low volume with the testimonies, and considerably higher with the music. Guess it was a combination of the board man tweaking the input line, and the cameraman tweaking the volume levels at the camera. Question is: Is there an easy way in Audition to “smooth out” (for lack of better phrase at the moment)the entire audio track to within the same volume range — that is, bring up the gain on the persons talking, lower the gain on the music — without going through the entire track and tweaking amplitude, etc., piece by piece?
    Ed
    “deja vu all over again” — Yogi Berra
    Ebarfield replied 20 years, 3 months ago 2 Members · 2 Replies
  • Willie Toth
    May 25, 2006 at 2:53 pm
    Ed,
    To do it properly there are no short cuts, one section at a time is what I recogmend … Normalize just works on the peaks and although doing a hard limit will bring up your low volumes it will also add gain to you louder volumes … Audio isn’t mircowave tecnology if you want it to sound right you need to put the time in and no matter how good the video is, if the sound isn’t quality the video will always be less than it can be ………… WILLIE
  • Ebarfield
    May 25, 2006 at 5:40 pm
    Well, that’s what I thought…I knew normalizing would not do what I needed, but was not too familiar with hard limiting. In the past, I have always done it the hard way, and just watched the meters as I go (and listened, of course) and either keyframed volume/gain in PP, or raised/lowered the gain on different sections in Audition.
    later,
    ed
