volume envelope issues
Hi
I want to turn the audio volume up ie peoples voices, noises etc at one point in the time line so that you can hear it above the music track.
I have figured out to add an envelope and points and raise the volume but no matter what try it you cant hear it.
I guess there must be some thing in the settings that i have overlooked, does anyone have any ideas or experience with this?
I have been searhing this forum for the last few days but have had no luck.
Any help would be greatly appreciated!Thanks
Hi John thanks for your reply,
I ended up using that “ducking” technique which was great in that i was able to finish the project but i really need to be able to raise the voice volume.
Any thoughts?
The Audio level is pretty reasonable if played normally ie; i have it at about -26db (but i’d rather have it right down because after i rendered it, it was actually louder and some noise came through) so that you cant hear the background noise but anything above that and it can get really loud. Yet still even when i put the volume right up on the evvelope it doesnt change at all despite the volume control physically moving as it hits the “non” event. I’ve tried putting in points and raising that in each direction aswell.
any further ideas would be amazing!
Thanks again
