Activity › Forums › VEGAS Pro › Volume Envelope
  • Volume Envelope
    Posted by Roger Bansemer on January 1, 2017 at 5:03 pm
    After adding a volume envelope to the audio track, is it possible to change a setting somewhere so the envelope automatically slopes more gently from loud to soft when pulling the envelope down? It does make a slight loud to soft transition but not very much.
    Roger
    Roger Bansemer – PaintingAndTravel.com
    László Kovács replied 9 years, 8 months ago 7 Members · 11 Replies
  • 11 Replies
  • Aaron Star
    January 1, 2017 at 7:59 pm
    You can control the slope of the transition by adding more points. Then moving those points to create whatever slope/fade you need, whether that be sharp, stepped, or long and drawn out.
    Is that what you are asking, or are you asking about some default setting to make all future edits the same?
  • Roger Bansemer
    January 1, 2017 at 8:08 pm
    Yes, I was looking for a default setting that might be changed. It’s no big deal but thought if it could be changed it would same me some time.
    Roger
  • John Rofrano
    January 2, 2017 at 12:42 pm
    [Roger Bansemer] “After adding a volume envelope to the audio track, is it possible to change a setting somewhere so the envelope automatically slopes more gently from loud to soft when pulling the envelope down?”
    You can right-click on any point on the Volume Envelope and change the fade type.
    Like this:
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
  • Roger Bansemer
    January 2, 2017 at 2:05 pm
    I never noticed the “fade type” before. Thanks for pointing that out.
    I guess there is not a way to change the “slope” of the fade other than grabbing it and putting it out. I’ve got music with lots of intermittent voice overs and I thought there might be a way to change the slope default.
  • Graham Bernard
    January 2, 2017 at 2:13 pm
    [Roger Bansemer] “I thought there might be a way to change the slope default.”
    What a great question/request! Hmm….
    * Grazie
  • László Kovács
    January 2, 2017 at 6:19 pm
    there can be a workaround, you can try if it works for you.
    Simply ungroup and split the audio, change the level, and do a crossfade.
    The length of the crossfade will be the “slope” if I understand right what you need.
    Here’s a quick example what I mean:
    Not so flexible as the volume envelope, but if it’s only about to temporary lower the volume of the speach/music it’s quite quick and comfortable to do so 🙂
    Best regards
    László Kovács
  • Mark Barton
    January 3, 2017 at 6:24 pm
    I have not tried this yet, but it may be another option, is the less than $10 FASST app Voice Assistant. https://vasstsoftware.com/product/voiceassistant/
  • Roger Bansemer
    January 4, 2017 at 3:52 pm
    That’s a very clever workaround. I’d just have to careful if I eliminated an event not to cut the music short.
  • Roger Bansemer
    January 4, 2017 at 3:53 pm
    I’ve just recently installed all my programs on my new computer. I think I may have this program already. Thanks for that tip. I’ll give it a try.
  • Paul Berk
    January 4, 2017 at 8:22 pm
    This is fairly automated in Vegas now. I keep forgetting it’s there .. but this might help.
    https://www.amybear.com/Dip_Music.mp4
