Activity Forums Panasonic Cameras voltage and cables
  • voltage and cables
    Posted by Robin Probyn on April 27, 2008 at 2:19 pm
    I know might not be the right forum,but just a quick question re voltage.Will I have trouble using extension cables built for 110v in a 240/220v country.
    Will they melt? or be ok.Just for use with 500w lights. 2 or 3 only.
    Robin Probyn replied 18 years, 5 months ago 2 Members · 2 Replies
  • John Sharaf
    April 27, 2008 at 3:30 pm
    Robin,
    Yes, wrong forum. Try “Lighting Design”. But to save you the effort, cables will be fine; actually 220v uses thinner cables as more voltage requires less amperage for same wattage. You will need adapters plugs and remember to switch out your globes to 220v versions or else yours will pop when you plug them in. Alternative is to wire a series pigtail so two 110v units in series equal 220 volts, then you can use present bulbs. If you understand what I’m talking about you’ll know what to do!
    JS
  • Robin Probyn
    April 27, 2008 at 11:57 pm
    Ok thanks!
