Activity Forums Boris FX Volleyball/Baseball/GolfBall Texture for spheres
  • Volleyball/Baseball/GolfBall Texture for spheres
    Posted by Mark Santella on November 24, 2007 at 1:54 pm
    Can I map a sphere with a texture similar to a volleyball or other ball that looks 3d? I know how to in Zaxwerks, but does Red support such a thing. Thanks for your help.
    Peter Mcauley replied 18 years, 9 months ago 2 Members · 1 Reply
  • Peter Mcauley
    November 26, 2007 at 3:33 pm
    The trick to achieving this effect is to create a 3D Sphere track, then add this to a 3D Container track. When you move the SPhere into the Container, the Sphere then has a new tab titled Bump Map. It is via the bump mapping that you can give the Sphere a 3D appearance. The bump map tab includes an option to set the source to use either procedural based textures or raster image based textures.
    I hope this helps.
    Peter.
