Activity Forums Apple Final Cut Pro Legacy Voiceover Tool no imput
  • Voiceover Tool no imput
    Posted by Franco Bogino on July 28, 2006 at 9:33 am
    Hi
    I am having a problem getting an imput through the voiceover tool. Until recently we have been using a basic mike plugged into the line imput on the mac, which has worked fine.
    Now we have a proper mike hooked up to our sound/ video card (Blackmagic Multibridge Extreme) via a mixer, and can no longer get an imput via the voiceover tool.
    I have changed the imput selection wijthin the VO tool to multibridge, no success.
    The mike is working, as I can get an imput via the Caprure window, so at the mo I’m recording VO in a similar way to how you’d do it on an Avid.
    This poses it’s own hassle, as I have to switch the multibridge to one of the settings I wouldn’t usually use for digitising. Also, I am working at HiDef, strangely, no sound comes through the capture tool if It is set to digigtise on HiDef, so I also have to switch this to one of the SD settings.
    Anyone able to shed light on this?
    Cheers
    Franco
    Xtothed replied 20 years ago 3 Members · 5 Replies
  • Andy Mees
    July 28, 2006 at 12:39 pm
    what settings do you have set in your Decklink Preference pane for input? if you have the active input set to SD/HD SDI only then the you will indeed get nothing from the analog input on the multibridge
  • Franco Bogino
    July 29, 2006 at 12:59 pm
    I have set the multibridge to analogue imput. As I said, I am getting sound into FCP, but only through the Capture tool, not through the voiceover tool.
    Franco
  • Andy Mees
    July 29, 2006 at 1:54 pm
    VO Tool can be a little picky about when it chooses to work … I have a Multibridge Extreme in the office, so if the problem is not solved before Monday I’ll take a look.
  • Andy Mees
    July 29, 2006 at 1:56 pm
  • Xtothed
    September 7, 2006 at 12:15 pm
    Did you get an answer to this query…i am having exactly the same problem
    xavier
