Activity Forums Adobe Premiere Pro Voiceover Recording and Levels Monitoring Troubles
  • Voiceover Recording and Levels Monitoring Troubles
    Posted by Mike Gurfield on February 1, 2018 at 1:15 am
    I’m on a Mac on Premiere 2018 current iteration.
    So I’m trying to do some basic VO. I have a new Focusrite audio interface, and a decent Condenser mic setup. I can’t for the life of me seem to be able to get audio level monitoring working while I’m recording in Premiere. I can get level monitoring in the Voice-over Record Settings dialogue box, but as soon as I close out of that box, and into the timeline record function, I do not get any monitoring. I don’t get any readings in the Audio Track Mixer, and nothing on the Audio Meters. I get plenty of levels during playback, and VO IS getting recorded. I also don’t get any level information if I record through the Audio Track Mixer rather than through the timeline. So I’m clearly just missing a toggle somewhere, I assume, but am wracking my brain trying to find it. I’ve got all my audio hardware preferences IN/Out set to look for my interface, and I am getting sound passing through my interface to my headphones. Any thoughts?
    And my OTHER question is just something weird I’ve been experiencing. When my interface is hooked up, and I scrub through clips, the audio is garbled/unintelligible, even at very slow scrubbing speeds, where as when the audio interface is not connected (or premiere is pointed towards my built-in audio output), I get very normal sounding audio, just played rapidly depending on my scrub speed (as I’m used to). I’ve got “Maintain Pitch” and “Play Audio while scrubbing” both checked. Any ideas why this might be happening? The DA converters on Focusrite’s should be able to handle anything I’m throwing at them, so I’m a little confused…
    Thanks in advance future internet friends!
    Mike
    Ricard Rinaldo replied 7 years, 7 months ago 3 Members · 7 Replies
  • 7 Replies
  • Mike Gurfield
    February 6, 2018 at 12:17 am
    Still hoping someone can figure out my leveling mystery… Any hints?
  • Paul Henry
    October 29, 2018 at 9:48 pm
    Hi Mike, wondering if you figured this out, having the same problem.
    Paul
  • Mike Gurfield
    October 29, 2018 at 10:42 pm
    Sadly, no. Essentially I’ve either had to turn the gain to a relatively safe guess and hope, or record in a separate DAW.
    Maybe it’s fixed in 2019, but I’m not gonna upgrade on the dot oh release.
  • Paul Henry
    October 30, 2018 at 1:50 am
    Thanks for response, I’ve got a fresh copy of premiere and I’m seeing the same problem still. I’ll let you know if I figure it out, got to be a setting or something like that. I had a problem with my USB Mic, which turned out to be that premiere needs “permission” to use the Mic, as granted in System settings security/privacy option. I called up Adobe and a Tech spent 45 minutes or so finding the problem, good service.
    Paul
  • Paul Henry
    October 30, 2018 at 2:09 am
    PS: just found an Adobe video tutorial which shows and even demonstrates that no level indicator is to be expected. Strange.
    https://helpx.adobe.com/premiere-pro/how-to/work-with-audio-voice-over.html#
    Paul
  • Ricard Rinaldo
    December 27, 2018 at 2:20 pm
    This is what I did to get my internal microphone on the imac to work.
    Took me a couple of hours to troubleshoot this since I had audio in other programs from this source.
    If you did not “allow” premiere to access microphone when you installed it, chances are that you need to check a box in the system preferences.
  • Ricard Rinaldo
    December 27, 2018 at 2:23 pm
    Since that failed and I cannot find a way to edit or delete my previous post I try again.
