Activity Forums VEGAS Pro Voice Recording
  • Voice Recording
    Posted by Tonys on June 15, 2005 at 3:41 am
    Hi All,
    I am currently doing voice recordings for a corporate video production but am find as I read the scrip my voice comes in strong & then levels out. Is there a way in Vegas to level my whole audio voice recoding?
    Tonys replied 21 years, 2 months ago 2 Members · 4 Replies
  • Peter Wright
    June 15, 2005 at 3:53 am
    You can do some levelling visually or aurally with a volume envelope, but it sounds as if the way you’re recording may be the cause – are you using some sort of auto gain? You need to set an appropriate level and keep this constant.
    (Unless of course you’re starting to read at a louder level then dropping your voice!)
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
  • Tonys
    June 15, 2005 at 4:08 am
    Yeah I am Peter, Starting loud then dropping. There wouldn
  • Peter Wright
    June 15, 2005 at 4:29 am
    Compression may help, or you could just split after the “loud” part and apply Switches > Normalize to the remainder. If that makes the rest too loud, drag down the top of the audio event to reduce gain – a visual comparison with the initial section should enable you to make both sides of the split equal.
    Peter Wright
    Perth, Western Oz
  • Tonys
    June 15, 2005 at 5:46 am
    Peter you
