voice over trap and mike rec.
Posted by Craig Alan on January 11, 2012 at 6:12 pmhttps://www.realtraps.com/p_pvb.htm
what do you think of this and can you give me some recommendations of vo mikes at around $1000.
thanks
OSX 10.5.8; MacBookPro4,1 Intel Core 2 Duo 2.5 GHz MacPro4,1 2.66GHz 8 core 12gigs of ram. GPU: Nvidia Geoforce GT120 with Vram 512. OS X 10.6.x; Camcorders: Sony Z7U, Canon HV30/40, Sony vx2000/PD170; FCP 6 certified; write professionally for a variety of media; teach video production in L.A.
Tony Koretz replied 14 years, 8 months ago 4 Members · 7 Replies -
Ty Ford
January 12, 2012 at 1:19 amHello Craig,
A (very) little absorption on the deaf side of any mic is not enough to overcome a bad acoustic environment except on CSI.
Try this: https://www.neumann.com/?lang=en&id=current_microphones&cid=tlm102_description
Regards,
Ty Ford
Audio Forum Leader
Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide -
Craig Alan
January 12, 2012 at 10:17 amThanks Ty. Comes in at $700. cool.
Can you recommend a portable sound booth of some kind or does this really take a room designed for this purpose?
Also if we were to use the TLM102 directly into an editing program will the mixpre-d do the trick. I know it can provide the phantom power required.
Also would you advise a thrid party shock mount or does the stand mount that comes with it do the trick?
Ty Ford
January 12, 2012 at 1:10 pmCraig,
Do you really need a booth? Tell us about what’s going on at your place.
Suspension mounts are important if you have a lot of structure born vibrations. If you don’t have that, you should be oK without one.
Mix PreD will work. You might want a pop filter.
Regards,
Ty Ford
John Fishback
January 12, 2012 at 3:17 pmI’ve never used a PVB, but our VO booth uses their bass traps which are excellent.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Craig Alan
January 12, 2012 at 6:14 pmThe video production class shoots a variety of short form videos, some of which require a voice over added in post. It is rare that we can record anything isolated from group noise. I have 4-5 production teams per class. This just looked like it was possible to block some of the surrounding environment.
Ty Ford
January 12, 2012 at 9:38 pmCraig,
That line from Dirty Harry comes to mind. Do Ya Feel Lucky? Well, Do Ya?
I have no way of knowing what you deem acceptable. While it will block SOME direct sound. I doubt it will be enough. Blocking sound like this from the rear of a directional mics really doesn’t buy you much.
Regards,
Ty Ford
Tony Koretz
January 17, 2012 at 9:55 amIf you are having problems with picking up too much noise from round the room you may want to consider the Shure sm7b as a VO mic. They don’t have a lot of gain and so require a good quite preamp with plenty of usable gain, but they have the advantage of allowing you to get really close to the capsule. If proximity effect is likely to be a problem, the ElectroVoice RE20 is another possibility as it has virtually no proximity effect ( ie: it doesn’t sound bassier the closer you get to it). Both are dynamic mics and require no +48. Both of these mics have a long history as broadcast announcer mics and are well under your $1000 figure, which means you have some money left over for sound treatment in the room.
Well acoustically treated recording spaces make a world of differencre to the outcome v untreated spaces.Rocksure Soundz
https://rocksuresoundz.com
