Activity Forums Apple Final Cut Pro Legacy VOICE OVER TOOL HELL! PLEASE HELP!
  • VOICE OVER TOOL HELL! PLEASE HELP!
    Posted by Sean Lloyd on November 24, 2005 at 10:25 pm
    Sorry for the dramatic headline, but I’m under the gun and really need some help. I’m using the voice over to to do some sync work. The tool itself records fine but when it gets to the timeline its out of sync and actually about 15 frames early. In other words I can hear that the material is being laid down in sync, but when it plays back it is 15 frames early. I even recorded a test using the voice over tool, then synced to what I recorded with it and still the same thing happened. When it went down they were in sync and when I played them back together there was a very noticable delay of 15 frames. I am very familiar with FCP audio and have used the VO tool succsessfully in the past. I haven’t changed anything in my set up other than downloading some of Mac’s recent performance upgrades. I spent hours going through my preferences and making sure that frame and sample rates were the same etc. so I’m now very confused. If anyone has suggestions I would really appreaciate it as I can finish this job without it. Thanks…Sean
    SPECS
    g4 1.2ghz
    FCP 4.5
    Mac OSX 3.9
    Sean Lloyd replied 20 years, 10 months ago 3 Members · 3 Replies
  • John Fishback
    November 25, 2005 at 4:28 am
    I’m not in front of my computer so I can’t tell you this exactly. On the Voice Over tool dialog box there’s an offset setting where you can affect the sync. I’m not sure if it will deal with sound that is early and I don’t think the offset goes as high as 15 frames. But maybe it will help. What interface are you using to input your audio to the VO tool? A crude way of dealing with the issue is to select the tracks after laying them down and offset them manually 15 frames.
    John
    Dual 2.5 G5 4 gigs RAM OS 10.3.8 QT6.5.2
    Dual Cinema 23 Radeon 9800
    FCP4.5 DVDSP 3.0.2
    Huge U-320R 1TB Raid 3 firmware ENG12.BIN
    ATTO UL4D driver 3.20
    AJA IO driver 1.3.1 firmware v21-26
    SonicStudio HD DAW, Yamaha DM1000, Genelec Monitors
  • Randy Hess
    November 25, 2005 at 3:19 pm
    Sean,
    Did you try dumping your preference files and rebooting?
    Make sure FCP is not running when you do this and empty the trash when done.
    Since you said you have used the VO tool before and it has worked well I suspect it is
    nothing you have changed.
    Randy
  • Sean Lloyd
    November 28, 2005 at 2:21 am
    Hi Randy and thanks very much for responding…
    I’m not sure what dumping your preference files
    means, but will look into it. Will this cause any
    problems with other projects that I’m currently working on or
    will I need to reset all my preferences for them?
    Thanks…Sean
