Activity Forums Apple Final Cut Pro Legacy voice over recording
  • voice over recording
    Posted by Rob Alexander on October 25, 2007 at 5:44 pm
    what’s the best way to use the voice over tool with an Io? When I try to set the input to PRO IO analog it tells me the device is in use by another application. I’ve figured this is actually because I’m looking at the output of final cut at the same time. Toggling video off does allow me to record but then when I go back to view all frames the video all goes crazy -purple or not there at all.
    I imagine people have come across this and there’s a method which works.
    Rob
    Dual 2Ghz G5
    4GB RAM
    FCP 5.14
    AJA Io
    John Fishback replied 18 years, 6 months ago 2 Members · 1 Reply
  • John Fishback
    October 25, 2007 at 6:07 pm
    Unfortunately, you need a separate interface for using the voiceover tool. The IO won’t work. Search the forum and you’ll find a lot of discussion about this.
    John
    Dual 2.5 G5 4 gigs RAM OS 10.4.8 QT7.1.3
    Dual Cinema 23 Radeon 9800
    FCP Studio 5 (FCP5.1.2, DVDSP4.1.1, Comp2.3, STP1.1, Motion 2.1.2)
    Huge U-320R 1TB Raid 3 firmware ENG15.BIN
    ATTO UL4D driver 3.50
    AJA IO driver 2.1 firmware v23-28
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neuman U87s, Genelec Monitors, PrimaLT ISDN
