Activity › Forums › Blackmagic Design › Voice over in FCP with decklink
  • Voice over in FCP with decklink
    Posted by John Delmont on November 15, 2005 at 3:59 am
    I am using a decklink extreme and Final Cut Pro. I select decklink in the voice over tool, but don’t seem to be getting any audio when I record. Have set the decklink prefrences to ntsc/pal analog XLR input, but still no luck. Any ideas? I’m coming from the Media 100 world and just starting to test the waters with FCP and Decklink.
    Trevor Kinsey replied 20 years, 10 months ago 3 Members · 2 Replies
  • Göran Thorén
    November 15, 2005 at 1:07 pm
    What you need is either a sound card on your computer or if you are on a Mac you can buy a little device called Imic. Since the new G5 doesn
  • Trevor Kinsey
    November 16, 2005 at 4:14 am
    I have lived this game and can offer you the following.
    You may be able to use the MAC sound input for the voiceover tool. You can set the VO tool to use a different input to the log and capture tool in FCP. This works on one of our Dual G5’s. The other machine is nominally identical and it doesn’t work.
    If you use the Decklink input as the input for the VO tool you will need to turn off the external monitor when you do recordings (under the view menu, external video – set to off). The trick is to get the external monitor to show black. If it shows anything other than black (i.e. no signal, not black video) say the desktop, you can’t record. Apparently this is the way Apple have set up the tool to work. This means you can’t do ADR or anything else that requires you to have an external monitor working as you record.
    You can also record audio only using the log and capture tool, but you have to supply a valid video signal, even if you aren’t recording it.
    Hope this helps.
    PS. I would be interested to hear if you can get the MAC input working. I still can’t figure out why it works on one of our machines and not the other.
    Trevor Kinsey,
    Technical Producer,
    CVP Film and Television,
    Melbourne,
    Australia
