Activity Forums Apple Final Cut Pro Legacy Voice Over Feature in FCP
  • Voice Over Feature in FCP
    Posted by Anna Panetta on November 17, 2005 at 12:17 pm
    Hi There,
    I have a G5 and FCP 5, and am using Voice over feature for the first time. I am using a crappy little microphone temporarily, but nevertheless, it should still work, i would assume. It allows me to record the voice over, however, when i have finished and the file is placed on the timeline, I can’t hear anything. I have noticed that the Sound Level meter doesn’t appear to be moving. Any suggestions on what I can do?
    cheers
    anna
    Pete replied 20 years, 10 months ago 4 Members · 3 Replies
  • Bouncing Account needs new email address
    November 17, 2005 at 4:09 pm
    How do you have the mic connected to the Mac?
    What input settings to the VO tool do you have in FCP?
  • Andy Mees
    November 17, 2005 at 4:17 pm
    make sure that you’re changing to the correct source and input…
    in the VO Tool window just under the Level meter you’ll see a popup menu item labelled “Source” and under that, one labelled “Input”, make sure you adjust those so that your source and input are both pointing to your mic
  • Pete
    November 18, 2005 at 4:09 am
    I do my VOs via my playback deck. With the mike connected to the camera, FCP set to “uncontrollable device” and Capture Now. Set your capure setting to audio only if you wish.
