Activity › Forums › Adobe After Effects › Voice is high pitched during ram preview
Posted by Derek Medina on April 16, 2011 at 1:24 amWhen I try to play my videos back in after effects, it sounds like chipmunks. Im not sure why.
I am using after effects CS5
windows 64 bit home premiumso thanks for any help you can bring me!
-Derek Medina
Joseph Urso replied 11 years, 8 months ago 6 Members · 5 Replies -
Brian Charles
April 16, 2011 at 5:25 amI’d check the frame rate and the sampling rate of the audio. Check under the File > Interpret footage > Main.
Jeremy Allen
April 18, 2011 at 3:37 pmI’ve recently had a similar issue. When I start an audio preview, it will play back faster and higher pitched. But if I stop it and start the preview again it will sound fine. I don’t have an answer for you, just wanted you to know you’re not the only one!
8core MacPro, 3.0 GHZ, 10GB RAM, OSX 10.5.8C4D 11.5
AE CS5
FCP 7.0.3 -
Robert crowther Lindeque
August 8, 2011 at 6:22 pmHi there!
I was struggling with exactly the same issue, and it drove me nuts! To make matters worse, I have a job I’m working on, and NEED to animate in AE. So I searched the net. Disappointingly there was nothing on the net. So I searched and searched until I at last found the solution. And what a no-brainer it was. Guess sometimes we think we’re so experienced, we fail to check the basics.
Check your Ram-preview, on mine the FPS was set to 30. Apparently this happens if you mistakenly use the “ins” key on the keyboard:D
Now all’s fine, hope it helps!
Cheers!
Ian Dillon
August 11, 2014 at 5:55 pmChanging the preview timing from “Auto” to 29.97 fixed it for me, even though auto was detecting “(29.97)”. Looks like a bug fix to me.
Mac Pro 2×2.66 GHz Dual-Core Intel Xeon
8 GB Ram
Blackmagic Decklink Studio 2 CardPlayroom Creative
We are an Orange County Video Production and Marketing company.
http://www.PlayroomCreative.com
