Activity Forums Compression Techniques vob to prores conversion
  • vob to prores conversion
    Posted by Peter Robertson on June 3, 2013 at 2:08 pm
    I’m trying to use the following:
    ffmpeg -i origingal.vob -c:v prores -profile:v 3 -c:a pcm_s16le ffmpegconv/converted.mov
    but I am getting the error
    Unrecognized option ‘c:v’
    I seem to remember having used the same syntax before with good results and no error but perhaps with another version of ffmpeg? I’m running ffmpeg version 0.8.12.
    thanks.
    Peter
    Pedro
    Chris King replied 12 years, 4 months ago 3 Members · 2 Replies
  • Reuben Martin
    June 4, 2013 at 1:10 am
    That version of ffmpeg is way too old. It neither supports ProRes encoding nor the newer argument style you are attempting to use. Update.
  • Chris King
    May 20, 2014 at 5:18 am
    As we know VOB such a kind of video file usually contains one or several audio tracks and subtitle tracks that are multiplexed together into one stream form. It is not the ideal format for editing purpose. A workable way I’ve used to convert VOB to ProRes 422, 4444 is using a professional ProRes codec converter.
