Activity Forums Adobe Premiere Pro Vob merge stutters
  • Vob merge stutters
    Posted by John Riker on February 22, 2014 at 2:26 am
    I have a DVD with some tv episodes. Each episode requires combining 2 vobs together. Since premier cc 7 can’t open them directly I have main concept totalcode which works. I create a sequence with one vob and then drag the second one after the first till they snap together. When I render its fine but there is a slight hiccup exactly where one ends and the next one starts. Any way to fix this?
    Thanks.
    JR
    EDIT: Note if I convert with Handbrake the full multiple VOB set for an episode it doesn’t have that stutter. Trying to avoid the extra transformation before going into Premiere though.
    Paul Neumann replied 12 years, 7 months ago 2 Members · 1 Reply
  • Paul Neumann
    February 24, 2014 at 12:41 am
    Just out of curiosity…try making a copy of the VOBs and then change the extension to .mpg. Import those and see if you still get the little bump.
