Activity › Forums › VEGAS Pro › VOB File Problem
  • VOB File Problem
    Posted by Antoine Guy on December 13, 2011 at 7:22 pm
    Hi All
    I have a dvd-r disc udf encoded. It contains solely three vob files. Each of these is a small piece(approx 15 mins) of amateur camcorder video. To be honest, I don’t know how this dvd has been chopped and mashed, I suspect there were at one time more vobs, but anyway that is not the main problem.
    I have extracted each vob file to my hard drive so that I may edit with Vegas. This is the strange thing; vob1 and vob2 can be opened by vegas but vob3 crashes vegas after about 56% of ‘Building Peaks’. However, VLC media player can succesfully play this vob3 file.
    Upon further investigation, by importing vob3 into windows movie maker, I notice movie maker thinks this has a length of over 25 hours, and consequently movie maker wont edit it!! (It actually is 15 mins on VLC).
    Can anyone please help me?
    Regards
    Antoine
    John Rofrano replied 14 years, 9 months ago 3 Members · 5 Replies
  • Mike Kujbida
    December 13, 2011 at 7:51 pm
    All I can suggest is to rename the problem file from .vob to .mpg and see if that helps.
  • Antoine Guy
    December 13, 2011 at 8:17 pm
    Nope, doesn’t work – exactly same vegas crash problem. Here are the details:
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 9.0e (Build 1147)
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:Program FilesSonyVegas Pro 9.0FileIO Plug-Insmcplugmcdddec.dll
    Fault Address: 0x24A014F0
    Fault Offset: 0x000014F0
    Fault Process Details
    Process Path: C:Program FilesSonyVegas Pro 9.0vegas90.exe
    Process Version: Version 9.0e (Build 1147)
    Process Description: Vegas Pro
  • John Rofrano
    December 14, 2011 at 12:26 am
    You can try File | Import | DVD Camcorder Disc…. If that doesn’t work, try a tool called Womble. It will convert the VOB to an MPEG2 file without re-encoding so there will be no loss in quality.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Antoine Guy
    December 14, 2011 at 10:08 am
    Thank you so much for your reply John.
    I tried the Womble program (free 30 day trial). Discovered that there were additional timebases in the vob3 file(mainly menu fragments). I removed these and saved a mpg. Vegas now has no problem opening it. Womble is a nice looking piece of software – Thanks once again.
  • John Rofrano
    December 18, 2011 at 4:05 pm
    [Antoine Guy] “Womble is a nice looking piece of software”
    Yea, it’s definitely worth having in your kit. I don’t use it often, but when I do, it’s the only tool for the job.
    ~jr
